Yes, I could do that.Will report back…
The reason I mention this is that I had an aluminum pipe on my roof in my LOS which was defecting the signal and causing multipath reflections so I moved the antenna to avoid it.
Also if you’re facing the broadcast towers which are on a mountain above you, you can tilt the antenna slightly upwards towards their location.
Makes sense. I will give it a shot. Thanks for helping me…
