Tablo Will Not Play Recordings
Since the Tablo update on Tuesday, when I go to recordings and select one, the only option I have is Delete. No option to play the recording. I have two Roku 3 players and the same occurs on both of them. The system is useless if I can’t play the recordings.
Also, the Recordings option is Recordings/All, no other options there either.
Did you press the down arrow to get to your recordings? By default, the first thing you see when you select a show is the delete button, but pressing down will display all the recordings of that show.
No, I had not. That worked! Thank you, Snowcat.
You are welcome. It sounds like you were using the legacy app, so the updated app was new to you. The Tablo folks are planning to change that screen soon to make it more user friendly.
