I am a new Tablo user, about 30 days. I assume that when the blue LED begins flashing and the show/recording I am watching stops it means a firmware update is in progress. Is this in fact the case? Twice this afternoon this happened while watching the news.
I searched the community site before posting, but couldn’t find anything specific to my question.
Thank you,
Ray
Did you touch the Tablo by any chance? I live in a dry climate, and if I touch the bottom front edge, Tablo gets a jolt of static electricity and reboots. I’ve since put it in a place where it’s out of site, out of mind, and haven’t had that problem since.
@rharing - No, we’ll prompt you when there’s a firmware update available for your Tablo. Something fishy is going on here so please do touch base so we can check your box out.
@rharing - OK, we’ll likely want that back into remote mode. Sounds like it may have rebooted in the night as well which it shouldn’t be doing. The support team will be able to help you figure out why it’s behaving like this.
Recommend every important electronic unit is connected to a battery backup outlet of a good UPS.
Especially the following:
Internet modem (cable, DSL, LTE, …)
Router
Network switch
Tablo
Externally powered hard drives
