Tablo time settings
Is there a setting for the time on the Tablo app?
I don’t see one in the settings option.
Unfortunately no. It uses the device time from initial setup or is based on your zip code.
Is the time wrong on your Tablo?
I think it is. Anyway to check it?
My zip code is correct. The times on my guide are also correct. But the times I show a program is recorded are off by 4 hours. I think the time is set wrong. Anyway to check it?
I don’t think there is a way to check it especially if the Live TV guide time is correct.
Is this issue with the recording times on ALL devices? Roku, Fire TV, computer, Android, iOS devices?
xxxx cccc xx cc
That’s what I thought, and that’s key, because then it’s not a global issue.
I was incorrect. It is on all of my devices.
xxxx cccc xx cc
Yes sir
Yes sir
@glucono1 - Touch base with support. They can look into this for you: http://support.tablotv.com/hc/en-us/requests/new
