Our previous external hard disk failed so we replaced it with a Seagate Extension 2TB. It doesn’t ask for a format but it is detected as a Seagate 2TB disk with 0MB Used…
When I record something the recording is available but selecting to watch it gives black screen with:
“Error: No storage available”.
Did you format the new drive? I found you have to briefly hit and release the blue reset button which will get you to the format screen after Tablo reboots.
I also had the same issue and this does nothing to get you to the format screen my tv went black after i hit the reset button and i have a new seagate 2TB since it showed no storage available
I seem to remember instructions for replacing a drive that went like this - I can’t find the post.
Boot he tablo without the drive attached.
run a tablo app that supports initial install - they all don’t.
enter the setup screen.
plug the drive in to the USB port
after a few minutes tablo detects the drive and that it’s not properly formated and a format option/popup will appear.
You seem to start out with a possible failed format " i have a new seagate 2TB since it showed no storage available" to “a new hard drive and shows 0MB used”.
I assume the line above show 0MB available.
Since you have tried most of the tricks you might be SOL until support looks. Tablo seems to think it has a good drive.
The only other trick I’ve seen in the past is to take it to windows and see if it sees the drive as a windows file system or ext4 file system which windows wouldn’t recognize - without the ext4 file system drivers installed…
