My tablo quad has a 8 tb hard drive 337GB used but all my recordings are gone can I get tablo to see my recordings again or are they just gone now any help would be appreciated.
Does the Tablo think the drive is connected? The Settings screen will tell you that.
Yes under storage WD Elements 25a3 1021 (8003GB) with 337GB Used
In that case I would reboot the unit and see what happens.
Rebooted the tablo and he twice by unplugging them from power but not the actual reboot button on the tablo
Thanks will do
