I had something record only 17 minutes and then nothing more on Saturday night. I figured Tablo rebooted on its own as well, but I was not using the Tablo at the time of the recording so I don’t know for sure why it stopped recording 43 minutes before the show ended. There was pixilation, stuttering, and then it just ended. I hadn’t realized the recording was short when I began watching it the following day.
@snzkickin We’ve been able to collect the logs from of few Tablo’s in the field to observe this issue. The Tablo will reboot (rarely) itself if it runs into a firmware error that we’ve identified.
@TabloSupport Thanks for the update. It occurred again yesterday evening around 5:40pm EST. If you need get any additional logs from my Tablo, please let me know.
Think mine rebooted tonight in Primetime uggggg! Would love to cancel Hulu+ subscription soon, thankfully I can get my Brooklyn 99 fix there tomorrow.
I hope this is why some of my recordings failed recently. When an update is released, will my tablo automatically update?
@mlnaficy, check out this info about what happens during a firmware update: http://support.tablotv.com/hc/en-us/articles/201457889-Tablo-Firmware-Update-Tips-Tricks
Thanks for that link:)
We've managed to gather enough data from Tablo's in the fields at this point. We're hard at work on a permanent fix which we intend to release ASAP.
Ok @TabloSupport, so I have been running pretty good for a few weeks then last night 2 shows cut off half way, I didn’t notice until I was watching the recording. Both 9pm shows cut at 30 minutes. Then While I was watching a how in front of the Tablo at 10pm I saw the light start flashing and boom. Lucky I saw so I could restart a recording.
So many unwanted Tablo reboots over the last week it’s unreal. It basically occurs daily and I’m at two times over the last few hours.
@snzkickin I know this doesn’t help you right now - but we’re working on it. This is very high on our priority list and we’re putting a lot of effort into fixing this.
This happened to me as well. It also explains why the device has been losing connectivity with wireless on occasion.
@snzkickin, have you tried putting your Tablo on its side? I am curious to see if that helps any of the rebooting problems.
@snzkickin , @snowcat is right about putting it on its side. I had issues and put it on its side and surprised that the times I have had issues has gone way down. Very surprised that it would cause that many reboots, but I was seeing a lot.
