Hi on one Nvidia shield (have another works fine) I can’t get ether One of the two Tablo apps to find my dual Tablo unless the shield has its Ethernet turned off and it is connected to wifi then no problem and it will connect fine. All other apps work and stream fine on Ethernet just not Tablo app. Rebooted Tablo, bypassed switcher and hooked directly to router and no go, uninstalled and reinstalled. . Worked fine up until a few days ago. Any help would be appreciated. Thanks.
Sounds like it’s already configured to WiFi, which disables Ethernet since it can’t be connected to both at once. Follow this procedure to switch from WiFi to Ethernet for connectivity…
