The Tablo is back now and status page is showing all green as well.
Given Tablo devices are connected to a physical antenna I wish the developers would do the authentication housekeeping in the background and enable customers to at least watch Tablo OTA channels - ideally with no artificial interruptions.
Tablo is usually pretty reliable. Yes, there are occasional problems, some that last longer than others. I won’t deny that. I find that the down time is comparable to what I used to experience with Cable or Satellite, but for a $100.00 box with no recurring fees, I don’t complain too much.
You happen to have started using your at an inconvenient time. Dig in and start using it. I think you will be happy.
