I was having trouble watching recordings so I replaced my hard drive with the recommended 1TB Seagate. My recordings were still hanging and out of sync so I tried a hard reset. Now I can not schedule recordings or watch live tv, on my Nexus 7 I get the following error
If you haven’t submitted a support ticket, I would go ahead and do so. The Tablo folks should be able to solve that error (or at least understand what causes it).
Just as a general troubleshooting tip, if you can delete (not disconnect) your Tablo using the web interface and then re-add it, then it will do a new sync and possibly solve your problem.
Hi @steve07 - I’ve received your ticket and sent you off a response. The suggestions provided by @snowcat and @piX64 are good ones. Feel free to remove and re-add your Tablo, and conduct a channel scan. Send me updates directly through your ticket when you can!
Thanks snowcat, your suggestion to delete then re-add the Tablo fixed it! It must cache some settings in the browser and on my Nexus 7 and then gets confused when the unit is fully reset.
