Tablo is working on Roku but iPhone, iPad, and iMacs all can’t find it will not connect I have restarted powered off, rebooted computers, network and NOTHING!
After a firmware update, it’s possible that your router could assign a new IP address to your Tablo making it difficult for your various apps to locate the Tablo at that new address.
In order to solve this, try re-syncing the app on that device.
Directions on how to do this and other basic Tablo troubleshooting is available on the knowledge base: http://support.tablotv.com/hc/en-us/articles/208223573-Troubleshooting-your-Tablo
tried re-syncing, rebooting, disconnecting hard drive, nothing works. Now I am unable to view all the channels I was once able too via Roku, nor is the Roku always able to find all the recorded channels. I know the OTA signal is good because I have swapped connection with TV to check, some of the strongest signals can not be found by Tablo, I get “Weak Signal” error. Basically since update it doesnt work.
Hi @Adam_Clark - Sorry to hear that. Our support team would be happy to help you troubleshoot and get things working again: http://support.tablotv.com/hc/en-us/requests/new
I have a call in, they worked on it today. So far nothing has worked.
