So I have noticed that if you have a recording that gets to bad of a signal it is no longer causing the tablo to reset. This is a great update as before if you had a bad recording on one channel then it would cause the whole thing to reset and recordings on others channels would be broken up as well. Atleast what I have seen since this last update they keep recording and only that one recording resets.
