I use several Roku units. I can get into the app and the guide will come up, but if I try to watch a channel, I’ll get the spinning wheel for a minute and then it’ll fail to load the live channel and go back to the guide. I’ll then power cycle the unit and go back into the app and it works fine. I don’t think it’s a DHCP problem as the app does still find Tablo, it just won’t load live channels without a reboot.
This sound like the Roku OS14 problem. Make sure you have the most up to date firmware on your Tablo. (Settings, near the bottom.) You want to be running 2.2.54. After you update, you should likely also turn on Audio Compatibility Mode.
Firmware is up to date - I even checked it again after the reboot tonight just to be sure. Audio compatibility is turned on. I tried it both ways before rebooting.
That’s a good idea. I did not the last time I had the issue but when it fails again, I will. Though I did try 2 different Roku boxes and had the same issue on both.
did you resolve your issue? i get black screen with channel info and channel does not come up. If i restart it, it will work but i have to do this everyday or multiple times. May play with audio settings.
