I just got my Tablo hooked up, and it seems to be working fine, then it will just lose connection. On the ROKU, it shows a half status bar and says “LOADING” and on the Fire Stick it will come up with an error that says “either loss of station or loss of connection”. I don’t know if it is the antenna or the WiFi.
Certainly sounds network related. Is the Tablo hard wired? Regardless, set it on it’s side or make sure it’s getting proper cooling (just in case that’s it, esp. if a 4 tuner Tablo doing WiFi).
Try to record. Make sure to pick the strongest channel as a test. Then see if this replicates for watching a recorded show. I’m wondering if there is a reception problem.
When I first got my Tablo, it took about a day to “settle”. I think between firmware update, guide data, and attaching a hard drive, it was a bit overloaded. I’m saying this because I saw the exact same symptoms as you describe for the first day. Now it appears to run flawlessly despite being on wireless.
@Fish I had no problems at all with the Seagate Slim line. 1 and 2TB, USB 3.0, no need for external power supply. No complaints at all on those. Often on sale, easy to find at a very reasonable price in my book.
