My tablo started to loose a lot of its scheduling. My wife has to check everyday to see if they are schedule, even so, at some time tablo tablo drop some schedule recording.
My wife is going crazy now.
The main function of a recorder is to record, if you cannot trust the device then it is just wasting electricity
You post went from “loosing a lot of its scheduling” to “drop some scheduled recordings”.
You would probably have to post some exact example for a specific zip code.
Of course if your wife is actually going crazy in the psycho with a knife fashion versus taking the broom out for a midnight flight fashion, you may not be able to post any information.
