Tablo hdmi and 4th gen
Can i still use my tablo hdmi AND my 4th gen on the same network?
I’m pretty, pretry, pretty sure you can, but you’ll need to have both Tablo apps installed.
@charles1212 You can indeed, but if you’re using the in-home streaming feature, you’ll need both sets of apps installed as @wysiwyggin mentions.
That obviously won’t apply to the UI on the Tablo HDMI itself.
Yes, this is my set up
