So do you have it as a repeating manual recording?
Yes, I do.
Ok, let me look at that… Thanks!
I think that without a guide subscription that data is not being encoded into the file because it is not being pulled from the guide data. Does that make sense?
I agree, my suggestion is to add the Air Date to the file name as that info is available.
I am doing that now, but my only concern would be with manual recordings that air the same day
Just sent you a PM
Some local news broadcasts only use the show name and nothing else, so that is one type that continuously overwrites the previous export. Some other Digital 2 channels don’t have episode titles or seasons/episode information included on the shows they are airing, so they keep overwriting exports if there are multiple episodes recorded as well. I have a guide subscription and many shows work fine, but there are a handful that would work better if the airdate and time was included in the file name to distinguish each episode.
Interesting, I will look into that also
Ok version 0.03b is updated and available at http://jettsoft.com/products.html
Don’t forget to get the latest version of ffmpeg at https://www.ffmpeg.org/download.html
Also make sure you have the latest Java from http://www.java.com/en/
This version includes naming of output files to include airdate when missing episode and title information.
Extract the zip file into a directory of your choosing.
You can run by double clicking on TabloExport.jar or run from a command line using java -jar (dir you put the jar)TabloExport.jar
Let me know if you have any issues or questions
Not trying to be a smart aleck or something, but I do wish Tablo would take a hint here at what supreme customer service looks like!
-Rodger
Difference being, if they make a mistake their business suffers, for me it is just something I do on the side
I just tried out the new version and everything works perfectly. It’s adding the date and times to the filenames and no longer overwriting shows without episode info. I can now batch export everything at once overnight. Your program has saved me a ton of time and added a good amount of value to my Tablo. Thanks a lot, Jestep. You’re the man.
This has also fixed the problem I was having with manual recordings being overwritten because of no Season/Episode data!
I exported about a half dozen episodes of two series last night and they all completed without a hitch.
Great stuff Jestep! Thank you!
This version includes the ability to sort the shows by Date Aired.
Sorted by Date Aired
Sorted By Title
@Jestep I’m thinking that I really need to find a reason to use your software.
I can’t for the life of me see why I would ever use this (I know that others do, it is just not how I use my Tablo or watch TV) but it looks so cool I want to play with it.
too funny
This looks like fantastic software. Thanks for giving this to the community, Jestep.
Is it just me or sorting by date doesn’t take the year into account? I have recordings done in June 2014 mixed with those done in June 2015.
Thanks for that catch, changed it to have year in front of month…
