I’m trying this out today for the first time, and while it looks like it’s finding my Tablo there are no recordings listed under it when I double-click. My tablo has been flaky lately (working with support) which is part of the reason I’m trying to export the content. Could be that flakiness is also causing issues with whatever API you’re using, but the HTML5 app seems to be getting content okay.
john-zanettos@John-desktop:~$ java -jar /home/john-zanettos/TabloExport/TabloExport.jar
Exception in thread “main” java.lang.UnsupportedClassVersionError: tabloexport/TabloExport : Unsupported major.minor version 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
Could not find the main class: tabloexport.TabloExport. Program will exit.
Same error as John Z:
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:637)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
Finally got to trying out your program Jestep. You have obviously put a bunch of work into it, Kudos! Still testing, but so far it works fine and I can see Tablo Exporter will work for me, and quite well I believe. I still have hurtles to jump, but at least there is a reasonable (even if not perfect) pathway to moving my Tablo content to my PLEX server.
There are a couple of things that would make an easier (and quicker) time of it and these may already be there to use, so I will ask.
For me to use MCEBuddy most efficiently, RAW TS files are the best. I am wondering if there is anyway to get those TS segments merged without any alterations into a single ts file? This would allow MCEBuddy to work much faster by using Comskip to remove commercial content much faster. I can then use TSMuxer to finish the conversion process into an m2ts file for PLEX.
I have 3 sets of content I need to process. 2 of these are on physical hard disk which can be connected to the Tablo, and 1 is on my RAID server. Swapping out between the 2 physical hard disks isn’t a huge problem, but having to copy from the RAID back to a physical hard disk is a bit harder. I will do this obviously if necessary, but it occurs to me they may be a simple way to access across the network to the RAID with Tablo Exporter. If there is, that would come in very handy for me, and quite possibly for other for one reason or another.
Anyway, just the way it is now, I do believe your efforts to make Tablo Exporter will work well for me. I really do appreciate what you have accomplished and available to all of us.
Very useful! I wonder if it would be difficult to add an option for the shows in the list to appear in order of the time it was recorded, so it would be quicker to see the latest recordings.
This version includes ability to export to a single .TS file. I am still looking into the sorting, which may be more difficult since it it is a single line value, but I have not given up.
Extract the zip file into a directory of your choosing.
You can run by double clicking on TabloExport.jar or run from a command line using java -jar (dir you put the jar)TabloExport.jar
