Folks,
I have a Tablo two tuner unit that I had set-up for a fixed IP address via Ethernet. I changed routers and the IP address range changed and I lost my connection. I have the Tablo up on Wi-Fi now but want to go back to a wired, fixed IP. Can someone point me to the instructions? I can’t seem to find my notes on how I did this last time.
@poohdog - Just connect your Tablo via Ethernet and hit reboot. Your Tablo will find the Ethernet connection and you should be good to go.
