Tablo disconnected middle of recording and never resumed
Hi, I have a 2 tuner Tablo with direct Ethernet connection. I recorded a football game earlier today and when I started watching it the Table went offline. It reconnected but it cut my game way short!
Does the Tablo have the ability to resume recording after going offline?
Offline, as in it no longer had an Internet connection or did it reboot, or what? What are you meaning by the term “Offline”?
It disconnected from the network. I reconnected it and resumed the game. The trouble is that it never restarted recording of the game again. Stopped at about 1hr15mins.
Almost sounds like it rebooted itself.
You might be right. I will check connections etc.
@Codebest has a valid suggestion, because network connectivity has no real impact on recording.
That makes sense. Unit was warm on the bottom. I have a cooling fan but it only runs when audio amps are on. I will change this.
Thanks!
Tablo will retry a recording several times before giving up.
