BraveUpNorth appears speechless.
There is an AT&T router that silently disables all port forwarding rules if a forward to port 443 is set up. Can you delete the rule for 443 and see what happens?
Since Tablo already had 443 green, the first thing I tried was forwarding the other two, and not forwarding 443. I figured heck, Tablo says 443 is green, why bother forwarding it, so I only did 80 and 8887 - you might note in an earlier picture that the rules were numbered 1-3 and 3 was 443, what I added when just the other two failed to fix the little issue.
So in a way, I already did that unwittingly because I setup rules Tablo1 and Tablo2 first, no luck, and added Tablo3 which was 443 later. Odd that Tablo always shows that green and the other two red no matter what I do, even taking out ALL rules and the UPnP it shows that 443 green and the others red. I assume it’s a Tablo issue or bug.
