According to Chapter 6 of the User Guide, the option to enable Tablo Connect should be on the settings screen, but I do not see it on my Tablo. Software version 2.2.2
Tablo Connect requires an active suscription to guide data.
That stinks. But thanks for the info.
If you know what you’re doing with networking, just set up a VPN server at home, some routers have this function built-in. All devices such as iPhones, Android devices, computers can connect to this VPN and to them it will be like their on the same local network at home so the Tablo apps will work.
