Tablo Acting wierd
My tablo is running firmware 2.2.2 I have not been prompted for any new update in awhile, and now it won’t connect through the web or any other interface. So, I did a factory reset, and the same problem continues, it keeps losing connection and reconnecting when it try to scan for channels, and the “Add channels to Guide” button doesn’t work. Is my expensive Tablo box toast? I hope not
Open a Support Ticket directly with Tablo Support. It does not have a 1 year warranty so can be RMA’d if defective.
@Ramon_Taylor Try rebooting your Cable/DSL/Fiber modem and your router and see if that helps.
