I have been using my Tablo 4 for quite some time and I’m familiar with setting up recording a TV program. I’ve notice in the last several days that when I have recorded a series’ new episodes, I sometimes find that there are TWO recordings of the season…one about 15 minutes and the second about 45 minutes. I don’t know WHY this started happening. Any ideas as to what I can do to correct this issue. Thanks, in advance, for your time, consideration, and response.
Segmented recordings usually indicate a reception issue that caused the recording to stop and start again.
Thanks for the response. Nothing has changed with the antenna placement but there have been a few VERY FAST / SHORT power outages in our area. I’m leaning on that explanation. I should be able to tell over a period of time.
Thanks, again.
