That was extremely helpful and with that information, some of us might be able to tweak our devices (not the Tablo, the tablet, PC, whatever) to make it work better with that scheme.
Too bad the “web based app” can’t store the info outside of the browser cache. Some folks actually flush the browser cache on exit - clear history, flush or empty cache on exit is a common setting for some. Not this person, I’ve got stuff on computers since the early 1990s and I just keep moving it forward to newer computers, but I know some who set that for frequent emptying. Knowing this we can work toward making it better on our end while you folks at Tablo make it better where you can, too. This is KB substance, IMO!
@TabloSupport thanks for the explanations! … very interesting… {and this is a perfect example of why you guys/company are awesome!}
My extraction program (which you really haven’t seen yet) uses a local cache as well…where I pull the list of rec_ids off the Tablo and do a difference, then from that I know what to delete off my cache and what to pull.
And while Tablo may be doing something similar, I have a feeling that images aren’t be handled well… that is, sure it’s an episode of Get Smart we didnt’ have before, but we already have the graphic posters, etc… so they shouldn’t get pulled again (I’m just guessing folks…)
Sync’ing is a bit of a disaster I’ve found. It used to be that I had to resync every couple of days otherwise I’d lose the ability to reach my tablo while remotely. Now the remote tablo feature while using my HTC One (M7) phone has stopped working completely. It teases me by showing the EPG but never actually connects. When I’m on the live listing screen it just cycles indefinitely with "Connecting in 5…4…3…2…1"
+1 for picture in the guide.
But this was never a promised feature from the beginning. For such a unique product, it works well. There is no other substitute that works as well as the Tablo.
Simple.TV has no support and lots of bugs.
Channelmaster DVR+ does not support multiple devices, it’s for one HDTV.
+2 for the picture in guide
I got things sort of working on my phone, it must be the app as I sure didn’t open a browser!
.18
24/7 Constantly says syncing here, but all system features work as designed. no issues, lucky i guess. Even remote connect works well
Thanks to Tim at support he remotely fixed my problem by clearing sync cache my Tablo was holding onto for some reason
