Thanks for your quick answer. How do I redirect the output of the command to a file?
@PhilH That’s what the “>filename.txt” does. Add that to the end of your command. You can change the filename if you want.
I just got a blank file.
@PhilH, what is the path to you ffmpeg file? Make sure it’s correct. You can also try adding the -d option and seeing the output no need for redirecting… it won’t do anything but will show you the commands it’s going to try to do…
(btw, my Windows tests were using Windows 7 64bit)
I placed the ffmpeg file in bin… w:\tablo convert\bin.
FFMPEG need to be the full path to the ffmpeg.exe (including ffmpeg.exe)
FFMPEG = 'w:\\tablo convert\\bin\\ffmpeg.exe’
or just because I hate back slashes…
FFMPEG = 'w:/tablo convert/bin/ffmpeg.exe’
Sorry… maybe location was a poor choice of words. It’s not the folder, it’s the fully qualified path to the executable.
That makes sense. I was only pointing to the folder ffmpeg was in. Let me try that & get back to you.
That did the trick… Thanks a bunch. I did install the 32 bit version of ffmpeg and the transcode line showed up properly & counted up from 0 just like the data line did.
@PhilH, yes, the settings unless you do -wcrop is merely copying the streams and stitching things together… so same quality.
When I redo the command handling, there will be more transcoding options and a more sensible way of adding your own…
Nice to see the progress things working… the one on ffmpeg is very probablistic (the only way to program!!)
But I thought my solution was clever… and cheap… there might be a better way…
I even got the closed captions to work once you told me that the exe file had to be in the path.
@PhilH, well, at least you didn’t post a pic (the pig thing)…
More good stuff to come…
And remember there are short options (-n -q -c -C in your case).
Goodnight my friend… You were a great help.
@cjcox I can see you do html/php and so on by your relative path use in the python script! you don’t start with the drive and give the full path, you start from your current location apparently and give a path relative to the path of the script - is that correct?
which includes drive, folders and file name like C:\apps\tablo\myfile.exe would be a full path. @PhilH, what is the path to you ffmpeg file? Make sure it's correct. You can also try adding the -d option and seeing the output no need for redirecting... it won't do anything but will show you the commands it's going to try to do....
Wonderful! That’s all I have, W7 64 bit. I’ve got more than enough processing power and RAM.
Script uses paths. Nuff said… The issue was the word path. In the case of the executables it needs to be the full path of the executable file.
Version 0.3 released.
See CHANGELOG and get file from:
SurLaTablo
What’s to come in 0.4? Well, I’m reworking the opts to make it easy to do multiple transcodes per entry. Thus you could create the Default .mp4, but also maybe things like an animated gif preview (for example):
MP4 is fine… I wonder if there are other resolution options for the MP4 output. Been a while since I looked at your script (ok, 3 days is a VERY long time for someone like me!)
@ShadowsPapa, when 0.4 comes out, it will make it “easy” (relatively speaking) to create custom profiles with whatever options you want. Just realize that a “resize” is an expensive full transcode. It will work, just takes a lot longer.
I’m kinda hoping that folks see where this is all going and that eventually you’ll be able to have a Plex-like browseable, playable interface in addition to a browser based extraction mechanism. No promises of what version that will come in though
Thanks for your hard work cjcox. It is appreciated…
