Hmmm… not totally sure. Usually I’d say you need to mount with utf-8 charset support. But you know, that almost looks like what happens when you can’t support long filenames at all. There really shouldn’t be a problem handling a question mark, which utf-8 isn’t even needed for.
So… while I haven’t exact done the test specifically as you have defined… I’ve never had such an issue on any Samba system I’ve setup. Maybe there’s some kind of pre-Windows95 option or something that is enabled on your end (?).
Okay, I figured out a work around to the character issues. It’s not a problem since Plex is running on FreeBSD and has access to the UTF-8 filesystem and such. It’s only an issue when I need to go in and move files around or delete stuff. I just switched to deleting it from my Mac or directly from the Linux machine instead of my Windows Laptop.
A stranger issue though is that I have this in my conf file:
options[‘no_utf8_names’] = true
but it doesn’t take affect or give errors.
If I put --options no_utf8_names=true on my command line call to SurLaTablo it works as expected, removing the odd characters.
After a few days with -o postscript=true, it’s still skipping the last segment of the show. Getting the first part of the next show tho. hehe
Might have something to do with the 5 mins it records after a show that I can’t seem to stop it from doing. I want to throw this thing out a window so often…
I’ve been recording some concerts. In the web app page for a specific recording, it shows “Special, Music” under the title. Like Castle shows “Comedy, Crime drama”.
But I don’t see that designation in any of the metadata that SurLaTablo has. Is there any way to pick up those categories for query filtering?
Tablo has a closed API available under a strict NDA which prohibits disclosure. SurLaTablo is open source, and thus can’t participate. Originally, Tablo dumped all the meta data from their partner EPG source in a normal file. That change many many months ago to being a reduced set of meta data with references to data held elsewhere (e.g. the need for the API).
So… while it used to be possible and SurLaTablo did make that information visible, now as I get are reference codes. Which means, a static table can be build similar to the way I have to handle channel meta data since that too was removed.
Community wise we can build this table, but I need everyone’s help. For example I can tell you that for American Idol, the meta data code is 1890, 221 which maps apprently to Music, Reality. A series of The Middle is labled SitCom and has code 1180.
1890: Music
221: Reality
1180: Sitcom
So… via Tablo, you can get the friendly names, and looking at the raw meta data from the Tablo (i.e. surlatablo.py -i ) can get you the exposed numeric data codes for the genres.
I have no problem trying do so some of this on my own, but their are a ton of genres. And I’m not sure everybody is interested in having this feature, but I do think it would be cool to create this.
And I’m assuming the codes are uniform across everyone’s devices, it certainly could be that you need to create a mapping specific to your Tablo.
A genre_map is included now in SurLaTablo. It’s probably not complete, but is an attempt to make genre meta data possible again (${genres}). You’ll have to remove your SURLATABLO_ROOT files and regen (just do surlatablo.py to regen).
Also, I posted my current surlatablo.conf. It might help some folks out with some stuff. And it includes my channel map for people in DFW area (you might want to remove that if you don’t live near me… and change SURLATABLO_ROOT and IP address etc… Just an example folks.).
(720327) Texas Rangers at Houston Astros
Saturday, May 21, 2016 at 06:00 PM
KDFWDT(FOX) - 720p [3:00:15]
Baseball
Description:
From Minute Maid Park in Houston.
(723670) King Kong (2005)
Saturday, May 28, 2016 at 07:00 PM
KXAS-DT(NBC) - 1080i [3:05:20]
Fantasy;Adventure;Action
Description:
Peter Jackson's expansive remake of the 1933 classic follows director Carl
Denham (Jack Black) and his crew on a journey from New York City to the ominous
Skull Island to film a new movie. Accompanying him are playwright Jack Driscoll
(Adrien Brody) and actress Ann Darrow (Naomi Watts), who is whisked away by the
monstrous ape, Kong, after they reach the island. The crew encounters dinosaurs
and other creatures as they race to rescue Ann, while the actress forms a bond
with her simian captor.
(581629) The X-Files - s10e01 - My Struggle
Sunday, January 24, 2016 at 09:00 PM
KDFWDT(FOX) - 720p [1:00:15]
Drama;Science fiction
Description:
A web-TV show host approaches Mulder and Scully with a government conspiracy he
believes he has uncovered; a possible alien abductee shares information that
challenges Mulder's beliefs on the existence of aliens.
Ah love Steven Raichlen’s Project Smoke! Just built a fire pit (outdoor BarBQ pit) to do some of his stuff. We watch him on PBS Create (along with all the other good people). It is our favorite channel; wife says if we lose all of our channels, THIS ONE MUST COME IN!!!
I built a special loop antenna for VHF from copper refrigeration tubing coil just to ensure we get this one (channel 8 VHF in our area - 8.2). Kudos to PBS for this great subchannel!
Half of our recorded content on our Tablo is from PBS Create.
