With Comcast taking over our town’s cable contract I have a quick question about the web apps (both for the phones and PC web app.)
Correct the smartphone web apps can access the Tablo offline thus will not use an active internet connection. Streaming will be over the local network.
The browser app accessed through my.tablotv.com requires an active internet connection to make the connection to the Tablo (this uses a small amount of data), however when you're streaming it is done over the local network.
If this was not the case, then the speed at which you could stream would be limited by the upload speed of your internet connection (it is not). Hope this makes sense.
Of course the Tablo itself uses the internet to download the guide data and the posters, etc. so the Tablo is not without minimal data usage. Note if you do any remote streaming (aka Tablo Connect when away from home), this will use your internet data.
@RFSox - @theuser86 is correct. Tablo does need an active connection to the internet to verify with our servers but once that’s completed, everything else is streamed via your local network.
