Can anyone else check to see if they are seeing the same thing with their signal strength?
I know 100% that i have a bunch of channels that i scanned during a good tropo day that i can no longer get but they are still showing up at 100% 5 dot green signal when they should be zero.
@Pure10 Can you try another channel scan now and seeing if you can duplicate this issue? I’d refrain from doing these constantly - for example, if you conduct a scan during a storm, a network or two may not show up, and you’ll have to scan again later to pick it up again.
It would be a nice feature to have a dynamic signal strength meter. Right now, it only shows the signal strength at the time of the channel scan.
Ah makes sense now, I was thought it was a dynamic signal meter. :)>-
