It sounds like a problem someone is reporting in another thread. I’ll move these posts over there.
Please check out this post for more info:
I’m seeing the same thing with my Roku 3, whereas my Roku 4 isn’t experiencing any dropouts.
I’ve been recording at the highest bitrate. I’m going to lower it a notch to see if that has any impact.
In the spirit of “one thing at a time”, I am in the midst of upgrading from a Mohu Leaf to a Mohu 60 as I had a couple of channels that were showing as “strong signal” but pixelating on occaisions. I want to get a few days of experience under this new set up. In the interim, I’ll watch for audio drop out as I watch any recordings and will rewind and compare notes on location of the drop out but I don’t want to swap out the HDMI cable until after the burn in of my new Mohu. Also, I’m curious to see if the audio drop out continues with the Mohu 60.
@Bennie_Gibson Sounds like a plan! Make sure to run a new channel scan on your Tablo once the new antenna is connected.
Which specific Mohu did you get? I just recently tried upgrading from a Mohu Leaf 50 to the Glide which is 65 mile range and it looks like they have a new Chroma model as well that looks to be the Glide just in differerent colors.
I was having one channel in particular that would pixelate more than the others (NBC in this case) and I’m assuming it’s because it’s almost 25 degrees in a different direction then all the other local stations. Tried the Glide by itself and the Glide going into a combiner with the Leaf 50 and still couldn’t get the problem fully resolved. Ironically, after deciding to ship the Glide back under their 30 day money back guarantee and going back to the Leaf 50 other than the multiple issues we had Friday night the recordings have been solid, even on the NBC channel. In fact, we had NBC tuned and watching live for near 7 hours last night for the Super Bowl.
When the audio skips, it’s not in the same place when I rewind. Also tried switching out hdmi cables, no dice
Add me to the list of people seeing this…
I am experiencing this also. It happens only on my Roku (not my iPhone). If I skip back and replay the section, the sound will be just fine, or will drop in a different section of playback.I am using:
Roku 3 - 4200X v 8.0.0
Tablo Roku App v2.3 build 4
Tablo Model SPVR4-01-NA
Tablo Firmware 2.2.18
Same problem. Doesn’t drop in the same place when you rewind and replay.
having the same issue with live TV. every 20 secs or so the sound cuts out. Running 4 Tuner (just upgraded) from 2 tuner which didnt seem to have that issue. Running 2.2.20 on the Tablo, Hitachi Roku TV running software 8.1 and latest Firmware. Rescan TV channels and all show perfect signal. its getting old
I am still having this issue. Any fixes?
This can be caused by a few different things: reception, disk issues, etc. Our team can narrow this down for you - just send us a ticket.
I have the same issue, rewind and the sound is there again
I see it on an older Roku that I don’t watch on too often. Model 4200X
Has anyone got a fix for this issue? Sound is still dropping out for me on my Roku3.
Happens for me both on my MacBook Pro and all of my Apple TV devices, so its not just Roku.
