Is there a fix for no TABLO APP. I tried to add the app but it does not work.
What OS does the Sony HDTV run?
Do you mean you can’t install the app? Or that you can install it but it won’t run at all? Or it runs, but doesn’t do something else you expect it to do?
More specifics about exactly what you’re doing and what it’s not doing (that you think it should) would really help.
I believe that model TV is running Android TV. Is that correct?
