Some shows not recording or not showing up in recorded shows
I did the 2.2.6 update and have been generally happy with it. However, I have had 2 shows with recording issues. One is showing up in the recorded shows (the little orange tab has a “1” in it) but when I select it, then it says there are no shows recorded. The other was scheduled and showed that it was tuned in and seemingly recording, but it has not shown up in the recorded shows section. Any ideas? I really need to be able to trust the recording settings otherwise it’s not really worth it. Thanks
xxxx cccc xx cc
@Powerage - Touch base with Tablo Support. They can actually look at your Tablo to see what happened to this recording: http://support.tablotv.com/hc/en-us/requests/new
