IT has to do with what is going on when requesting a channel on particular clients.
I appreciate the explanation. Too bad there isn’t a “Just Live” mode on either device.
Thanks to this forum, I am really leaning toward adding a Tablo but don’t want to commit until I check out (eliminate) the Channel Master. I’d like the next purchase to be the last for a while. (Cordcutting startup expenses add up - antennas, hard drives, upgrading Rokus, etc.) I know it’s worth it though.
Yeah, sometimes its nice to just surf. A lot of folks will split their line and go direct to the TV when you need this.
@terryowen I’ve never found a PVR solution with desirable real-time channel changing capabilities… I find that navigating the channel guide and selecting the show to watch, to be acceptable… And so much better than the similar experience I recall from cable providers.
I’m just saying, for live TV, change the input mode on the TV and let the TV tune the channels directly. I split my antenna feed to Tablo and my TV and life just is better with a purpose built device… Doing it’s purpose.
I’ll probably get a splitter but I’m at the edge of the antenna range, so will likely need the preamp too. At least I can stop worrying about the channel-changing time now.
I’ve been a STV1 user for over a year now. The device has been relatively stable for months now. But issues during the Super Bowl lead me to give up on the device as soon as there was another device available to replace it. Enter Tablo. I still run both right now. STV1 records some shows and Tablo records all others. Tablo also is the go to device for live tv.
Don’t forget too, the higher the better for your antenna. If you can get it in your attic (or roof even better), you’ll get much better reception
Just to add, i’m way north of Chicago (about 45 mi) and get great reception in my attic.
I am about 68 miles west of chicago with a homebrew DIY attic antenna and get 69 channels.
I’ve lived in the north, west, and nw suburbs. They’ve all had much better reception than the south, sw, and se suburbs (including nw IN). In fact Janesville WI was better picking up Chicago stations than Joliet when I was there 20 years ago.
FYI: my antenna is my attic and both my tablo and stv1 share the same antenna. I get two vastly different channel listings for both. A good tuner makes a world of difference and the tablo device apparently has a good one
I appreciate the explanation. Too bad there isn't a "Just Live" mode on either device. :-)Thanks to this forum, I am really leaning toward adding a Tablo but don’t want to commit until I check out (eliminate) the Channel Master. I’d like the next purchase to be the last for a while. (Cordcutting startup expenses add up - antennas, hard drives, upgrading Rokus, etc.) I know it’s worth it though.
I was also looking at the channel master, but the thing doesn’t do is broadcast to other televisions or devices. That was the deal-breaker for me. The channel master is HDMI to a single TV set much like a Blu-ray player. The network connection to the channel master device is only used for guide access.
I’ve heard you couple pair the channel master to sling box to get recordings and such to other devices. Not sure how that would work, and it adds to the overall cost, but it “could” make the channel master viable when other devices are concerned
