New here & not a skilled user plus my hands are disabled. I simply want to sign up for subscription service. Tablo emailed me a serial number but it does not work. Why is it so hard to sign up for the subscription service? Plus where is a submit icon? Do you not want my money?
It has been a while since I started sending my money to Tablo for my subscription, so my recollection is hazy. The process depends on which device and application you are using. I am sure they would appreciate getting your money.
My suggestion is to contact the support folks by mashing here.
https://support.tablotv.com/hc/en-us/requests/new
I hope this helps – hang in there!
@darnmean To sign up for a TV Guide Data Service subscription go to: https://account.tablotv.com/
There you’ll need to create an account.
Once you’ve created your account, you’ll need to choose the Tablo DVR you purchased from a list.
If you choose the incorrect option, the serial number provided on the box and on the bottom of the unit will not work so make sure you select the correct one.
If you’re still having trouble, don’t hesitate to give us a ring:
