I upgraded my antenna to a ClearStream™ 4 Extreme Range Indoor/Outdoor HDTV Antenna after many adjustments I get strong green signal but still have some pixel/cutting out.
What could cause this ? Using an amplifier probably wouldn’t be good since i am near all towers.
How close are you to the towers?
There is some issues with having too strong of a signal.
The nearest tower is 9 km away and the farthest is 22 km. Today I went out and tweaked it again I find the tablo signal strength not the best. If it would be live, like satellite finder I could get it perfectly.
