TV show listings are not the same between my Roku 3 and when I use google chrome on my laptop. There are shows that appear on my Roku3 that do not appear on chrome. I've scheduled to record a few shows on the Roku (that aren't shown on Chrome) and would expect to see them in the "scheduled" section on chrome, and they also do not show up. This needs to be fixed so I can manage my shows on either device.
That’s not expected behaviour @blotto13. Please send a ticket with as detailed information as you can provide (which shows were different, on which channels on which platforms) to support.
I submitted a ticket and within a few HOURS they had responded with a fix. I was shocked, I assumed with a new product launch I may hear something in a week or so. Thanks!
@blotto13 - We aim to please Glad it got sorted out for you.
It’s nice you got your problem responded to. It would be nice to read the problem/resolution here
That would be helpful! The fix was to force a resync by disconnecting the tablo via the web app, deleting it, and then reconnecting. That process worked and it's stayed synced since then.
I ran into this problem this morning. On one of my PCs (a desktop running Win8.1 and chrome connected via wifi), the program guide wouldn’t update. Some timeslots under liveTv had listings, while a bunch did not. If I went to the scheduling tab, nothing was listed, though I could see all my existing recorded shows under Recordings.
@snowcat do let me know if this occurs to you with the latest versions of the web app. Lots of bug fixes since April.
So yeah let me know if this is still happening to you
I haven’t had it happen to me since that one time a month ago.
