I keep getting a message “show ended one minute ago” then have to go to guide to restart next show, anyone else having this issue?
It depends on how you started watching the show. If you clicked on the show itself on the Live TV grid, that’s how it supposed to work.
If you want to keep watching the next show on the same channel, you need to select the Channel icon on the left side of the screen.
