I am preparing to use my Tablo Quad OTA DVR. I have 3 TV’s, I don’t think any are SMART.
Where best to locate the Tablo:
upstairs, closest to antenna
in LR, because that’s the easiest place for me to interact with the Tablo
Assuming I am correct about the options, (1) which do you think better?
I think I need a Roku streaming player (Ultra planned, $50 today) for each TV (because Tablo doesn’t include viable TV controls -(2) Right?
While I am initially setting up the antenna, having the Tablo upstairs near the antenna would be best - (3) right?
I plan to see how well an indoor antenna works (window facing ideal direction). If not, I will run it into the attic or outside). In all cases I plan to run one coax cable from the antenna to the Tablo. (4) That’s best?.
I have mine close to the TV, because that’s where the antenna cable goes. Location depends very much on your situation. I’m not sure there is one best. I have some 30’ from the antenna, split with another50’ of coax. I’ve read other having more, many less.
I think the best is to have it split between the TV and tablo… you may not… again - not one best.
The one and onlybest… is what gives you the best results.
