If you’re interested in trying Plex, check out this how-to on setting up a Plex environment: http://www.engadget.com/2013/02/14/setting-up-a-plex-environment/
How cpu-intensive is the Plex Channel for TabloTV for the Plex server?
I would like to use my FireTV or another Plex enable set-top box, so I need to set up a Plex server as a conduit for the stream.
Is the Plex server transcoding the stream, or is the Plex just a wrapper.
… edited… looks like it’s transcoded in my case… but could just be my settings.
