Select channel to record new episodes from
Some shows premiere on multiple channels at the same time (Canada + US locations). I would like to be able to select which channel to use for recordings, currently it seems to pick at random.
Example I would avoid US networks recording new episodes on Sundays since sports tend to change its showtimes.
Feature will be here eventually. It doesn’t pick randomly, it picks the channel with the strongest signal.
https://community.tablotv.com/t/smart-scheduling-let-us-choose-the-channel/
Due to where I live I get a couple of networks 2 times. I only include once in the active channels.
Deselecting a channel works for cases where I get channels in both HD and SD or duplicates but the issue is its actually different networks. FOX (US) and City (CAN) both air Family Guy for example.
Signal strength response isn’t accurate either, upon further investigation is seems to always pick US networks over Canadian ones (my Canadian channels and much stronger).
