Currently have Tablo connected over wireless, have a pair of Powerline adapters coming today. How can I see the connection speed for the Tablo on wireless and then after on the Powerline/Ethernet connection? Operating system is Windows 10 home 64 bit.
Thanks
For your wireless router, you’d need to look up documentation on if, and where it displays real-time IP traffic.
What I do is bring up Task Manger in Win10, go to the Performance tab, and then look at the adapter (wi-fi or ethernet). Start playing a show on the Tablo, and you should see the network traffic go up and down.
To just see general network performance between the two adapters, you can run a speedtest from any of the speedtest sites.
