Would it possible to have scheduled recordings show by date / time or alphabetically with the times also shown? I was trying to find a time with nothing scheduled to rescan channels or upgrade the firmware.
If you use the web or tablet app, you can just look at the LiveTV screen. It will mark everything that is going to be recorded during the current 24 hours, so you can plan your rescan/upgrade using that info.
If you use the web or tablet app, you can just look at the LiveTV screen. It will mark everything that is going to be recorded during the current 24 hours, so you can plan you rescan/upgrade using that info.
Thanks @snowcat I didn’t think of that option.
