Not sure if there is a issue with tablo recording. Today noticed that all the scheduled Recording are not taking place. It shows coming soon on the TV if you go to the guide channel it shows recording but if you check the library there is nothing recorded. Just missed 2 of the recordings today.
Had to go to the Samsung TV and press the record button
Tablo’s own support doc on failed recordings says a failed scheduled recording should show up in the app with a failure message that names the cause, so the first step is to find that message for one of the missed recordings. The most common causes they list are reception problems (weather-affected antenna signal), a missing or disconnecting hard drive or cable, and on the QUAD a SATA drive that needs reseating. If there is no failure entry at all for these airings, my guess would be the scheduling or guide side rather than the recording itself - Tablo has a separate support article on guide and scheduling issues. With the exact error text, their support can usually pin it down quickly.
