Both my Scheduled and Prime Time tabs are always empty even though I have tons of scheduled shows to record. Makes it hard to delete schedules. I use iOS both iPhone and iPad. I am using all most current sw.
@rkoler If you’re not away from home at the moment, can you try deleting & re-adding the apps on your iPhone and iPad? It won’t delete your recordings or schedules, just force a new synch with your Tablo which hopefully should clear that up.
That do not help at all. Both tabs still empty.
Also. When I use the Roku app, the scheduled tab is empty until I choose Coming Soon. The Prime Time tab is also Empty.
