Schedule a recording for a specific time
When recording a show is it possible to pick the time that I want the recording to start and stop? For example, if I only want to record the last 30 minutes of a 60-minute tv show is it possible to set the device to start recording at 3:30 if the show starts at 3?
Hello Diane, and welcome to the Community.
The only thing I know of is to use the Recording Options page to offset the start or stop time. You should be able to set a start time for 3:00, then offset or delay the start time by 30 minutes. Unfortunately, I don’t see where you can offset the start time by 30 minutes. Check out this article for more info.
Thank you. I will give it a try.
