I tried scanning channels on AppleTV. They scanned but when I selected save and exit they did not save. I solved the problem by scanning on my Android phone and save. They did save this way. I thought @Tablotv might want to check out the problem
Hey @beastman - We’re not able to replicate the same thing.
Can you try again and make a note of the exact steps you took?
I will tonight.
