The Tablo channel on the Roku stick is not showing recordings. I can see the recordings on the web based app on the computer, but it is not showing on the Roku Stick. I tried rebooting the stick and also deleting and adding the channel back, but the recordings are still not showing. Any help please. Thank You.
To clarify what Jestep said, The A-Z listing will show all recordings. If that is blank, then there definitely is a problem.
@snowcat, yes that is exactly the problem. Title A-Z is default and does not show all my recordings. Funny thing is I can see them loading when the processing box is up. Also, moving to another does not show the artwork until I scroll down, might be by design.
@Jestep We just noticed this recently. We’re going to take a closer look to see if it’s specific to 6.1 (which at first glance, it appears to be) to see what’s causing this.
So how do you change the sort order for the recordings? I can’t find where to do it. Thanks.
When you select Recordings on the Roku, it lists 4 sort options. Genre (popular), Most Recent, Genre (A-Z), and Title (A-Z).
When I select recordings on the Roku Stick, it shows no such options it just says “No Recordings” when I select recordings with no chance to change the options.
@acronym3 did it get updated to 6.1 recently?? Might want to open a ticket with @TabloSupport and see if they can help more on this, what @snowcat described is how I get to the different sorts on my Roku 3
