I just got a Tablo. Everything seems to work great except for streaming to my two roku 2’s. I have a roku 2xd and a roku 2 xs. I can stream to my iPhone and my iPad. I can stream to my iPhone remotly with the Tablo connect turned on. However both my roku’ cant stream for longer than a minute without going back to the loading message. My roku is close to my wireless access point and has no trouble streaming any other media from plex to Netflix.
Are you having buffering issues with Live TV and recordings? Or just Live TV?
If just Live TV then under Settings on the Tablo uncheck Live TV Fast Startup.
It only happens with live recordings. The only place I could find to change that setting was by using the web app. I changed it there. Does that apply to all the devices? I have the stream set to Roku/Chromcast. It seems to be a little better, but it still stops and goes to loading every couple of minutes. It starts off loading every ten seconds or so, but then it gets better, but still never stops going to the loading screen. Is this a bandwith issue with the roku 2's?
