Used Tablo Ripper to rip some 1/2 hr shows and got 750+ meg files. Is this normal? How can I reduce the file size?
Eckhard
Eckhard
At least two ways:
I get HD half hours at about 2.22GB, SD half hours at 600MB. You could use Handbrake to squeeze them further if you wanted. It has a lot of presets that you could play with including h.265.
Thanks for the info guys.
