I check my settings from time to time on the Tablo web app- I have set the Remote Streaming Quality to 4 mbps… when I check this setting a week later it is back to 1 mbps…is this the norm?
The Remote Streaming quality setting is the only Tablo setting that is set per device rather than global. So you likely were using one device when it was set to 4 mbps and another at 1 mbps.
Thanks- I will check my other devices…
